Solved
Need expert help
  • New Build
  • Systems
Last response: in Systems
December 27, 2009 10:50:38 PM
will evga GT 240 512MB DDR 5 cause me bottle neck? or any other problem?
biostar nf520-a2 mobo, 2.8ghz athlon x2, 2x2gb ddr2 800
windows 7 64 bit ultimate, 600 w power supply
currant resolution 1440x900
More about : expert
December 27, 2009 10:53:46 PM
The GT240 isnt very strong, its about as strong as a 4670 so it will likely be the limiting factor in game performance, but in regular usage it wont limit you.
m
l
December 27, 2009 11:10:21 PM
what card would be a better match for my system? with current specs
m
l
Best solution
December 27, 2009 11:15:39 PM
Something like a GTS250 or HD 4770 would do quite well, a 5770 would be low power like the GT240 and would allow you to max out detail levels at that resolution.
December 27, 2009 11:21:31 PM
ok i will look for GTS250, what is best 512mb ddr3 or 1gb ddr3
m
l
