Hard drive replacement for Travelstar 30GN (will this work?)
Archived from groups: comp.sys.laptops (More info?)
The hard drive on my Portege 4010 just kicked (clicking / won't boot / media
failure messages) and I need a replacement fast.
The hard drive is an IBM Travelstar 30GN (30GB). http://tinyurl.com/6453e
From the hard drive documentation, it appears that the interface is ATA-5.
The drive I am looking at as a replacement(Hitachi 30GB / 5400RPM
http://tinyurl.com/5zuay )
has an ATA-6 interface.
Will I be able to use this as a replacement?
2 answers Last reply
More about hard drive replacement travelstar 30gn will work
  1. Archived from groups: comp.sys.laptops (More info?)
    Yes, but you could also take advantage of the situation and buy a
    bigger drive. You would get more bang for your money (lower cost per
    GB) with a higher-capacity drive.
    -Dominique
  2. Archived from groups: comp.sys.laptops (More info?)
    Gotcha- Thanks-
    "Dominique Pivard" <domi@kenavo.NOSPAM.fi> wrote in message
    news:f33df09lj5qiaf7o71fkipsm32l7cu0ao7@4ax.com...
    ATA-5.
    > -Dominique
Hard Drives Travelstar Laptops
