Hi all. My drive is a Seagate ST32000542AS 2TB drive. These were pretty popular over the last year or so. I own 4 of them, all purchased around the same time.
One of them died. Initially, I was able to boot into SeaTools for DOS and it gave me an error of 9BEEA743 on the drive. Now the BIOS no longer sees it at all. Tried it in other computers and external cases. No weird sounds, so I figured it was a PCB issue.
Since I have 4 of the drives, I swapped the PCB from a known-good drive onto the bad drive. No dice: upon spin-up, I could hear the heads load and unload around 10 times before going silent and the drive was not accessible. I tried this with all the remaining boards (just in case there was some subtle differences), but with the same non-working result.
All the drives have the same model number, same firmware, same manufacture location, same numbers stamped into the PCB, same stickers attached to the PCB. Still, somehow incompatible with each other. As a test, I tried putting a good board onto a different good drive just to see if there was some kind of incompatibility even between working drives and there was! Same load/unload of the heads on spin-up. WTF!
Is Seagate locking their PCBs to the drives or something? *sigh*
Any thoughts out there as to what I can do now to get this drive running? My last resort is to send the drive into Seagate's recovery service to see if they can get my data back, but I am scared of what the bill might be...
Thanks!
David
Thanks!
David
