Tagan as a power supply
Hi guys,
First of all, this is a great forum =).
My old PC started to be faulty (motherboard) so decided to renew it, I am pretty sure I need a new processor, a motherboard and memory. So far I have chosen:
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
Intel CPU Core i7 920 2.66GHz
Corsair memory DDR3 1333MHz 4GB kit of 2x204pin SODIMM Unbuffered
I have some other components like 2 HDDs (6 and 3 year's old both SATA), TAGAN 450W (3 year's old) which still works. The question is if I can use them with my new motherboard. What do you think. I would be happy if I did not have to buy a new power supply.
Thanks for any suggestion in advance.
4 answers Last reply
More about tagan power supply
  1. It really depends on which GPU you are using.
    They should all work together, just a matter of being able to provide enough power...
  2. yeah sorry i did not mention that. I am going to use graphic card: Gigabyte Graphics Card GeForce 9800GT 1GB GDDR3 PCI-E 2.0 DVI-I which needs 2 x 6 pin Power Connectors
    Thanks shravankale I will go and have a look at your link.
    Thank you
  3. It should work fine!
Power Supplies Intel Motherboards Components
