So I am buying a new computer soon and we have finally decided on a not quite good computer, but decent enough to play what it needs to.
I kind of have a problem, because I am buying a GTX 480 (for $200) off of Newegg, and although it is the best card (by far) to get for that money I am kind of scared of it because of the extreme temperatures that it (reportedly) goes up to whenever you play.
Here are/will be my specs:
Monitor(s):
2x Hanns 5ms Widescreen LED-Backlit LCD Monitor 250 cd/m2 X-Contrast 30,000,000:1 (800:1) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
Desktop specs:
Model: Gamer Extreme NE955i
Processor: Intel Core i7-3770k 3.5GHz 64 bit Quad-Core Processor 8MB L3 Cache
Memory: 16GB DDR3 1333 (4GB x 4)
Hard Drive: 1TB SATA III
SSD: either;
OCZ RevoDrive OCZSSDPX-1RVD0230 PCI-E 230GB 4 x PCI Express MLC Internal Solid State Drive (SSD)
or
OCZ RevoDrive OCZSSDPX-1RVD0050 PCI-Express x4 50GB PCI Express MLC Internal Solid State Drive (SSD)
Optical Drive: 24X DL DVD+/-RW Drive
Graphics card: EVGA 015-P3-1480-KR GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Audio: 7.1 Channels
Power Supply: 600W
Operating System: Windows 7 Home Premium 64-Bit
Special Features:
NZXT PHANTOM 410 GAMING CASE WHITE
iBuypower Custom Liquid Cooling
Motherboard Name: GIGABYTE GA-B75M-D3H
Dimensions: 20.9" x 20.3" x 8.5"
So bottom line this does (apparently) come with liquid cooling for (I assume) the CPU. This takes care of that, however I still (probably) need liquid cooling for the GTX 480 since I have yet to find anything that works better, and in theory and in tests the liquid-cooled GTX 480 should use a bit less watts while standing by, and noticeably less while running at full capacity.
I need some help! I also realize I may need to change my power supply because 600W does not seem sufficient for the GTX 480, however if possible I would like to not do that since I am already close to $300 over my budget for this machine and do not aim to go much higher.
Also; if you have a different idea to cool the GTX 480, please tell me! I am open to any type of cooling that is shown to work, but so far I have seen that fans do not make the heat dissipate fast enough, so I would be stuck with a super high temperature for my video card.
I guess I should tell you guys what I aim to be able to do with this machine too- I want to be able to play Creative Assembly's Rome II Total War at Ultra for everything once it comes out in late 2013. This should approximately be the same as Shogun 2 Total War at ultra settings too.
