Current Specs :
Intel i7 2600 ( 10 months old )
GTX 560 Ti ( brand new )
Using stock CPU fan .(
Windows 8 consumer preview + DoTA 2 heats my cpu over 65 degree celcius ( all low Graphics setting and aspect ratio and resolution ) and my brand new GTX 560 Ti locks on 50 degree celsius.
While assembling my PC recently i did a bad mistake of not putting the CPU fan on properly and let my CPU heat for over 85 degree celsius for over few minutes , and iam assuming that my CPU tends to over heat now without much usage*
Like i mentioned i use windows 8 , and just Opening Skype (Skype when Idle no calls ) shows CPU usage go 14% from 1% and the temperature goes from 38-40 Degree to 50~55 Degree.
Iam Planning to replace my CPU with a i7 3770K ( ivy bridge ) , being a processor that consumes low power means its safer from over heating ??? ( need some one to clarify if this is a good selection )
and back to topic here are the pics of my Assembly i need to know the best fan arrangement ( blow / suck )
TOP LEFT FAN 140 mm << OUT FLOW >>
TOP RIGHT FAN 120 mm <<OUT FLOW >> ( SOON 140 mm Replacing )
REAR 120 mm <<OUT FLOW >>
FRONT 140 mm << IN FLOW >>
Bottom Left 120 mm << IN FLOW>> ( 140 mm REplacement soon )
Bottom Right << EMPTY , NOT Sure if Putting a 140 mm on left side would allow a 120 mm to fit in >>
BTW from the picture you can see that the graphics card is a GTX 560 TI ( GIGABYTE 2X WINDFORCE ) version 1gb ddr5 ......it also runs hot (idle 40 and dota 2 at low settings 50~ 58 ) so i need some solutions for this problem also
Thank you in advance for any help offered
( Brand new )CM 690 II Advanced Nvidia edition Case
)1. Need a best 100$ solution for the CPU
