Hi all,
I been struggling with my network set up for the past couple of days and i would like some help on setting my network up.
Thanks,
Equipment:
1. Dynex DX-WEGRTR
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
2.Linksys WRT150N with DD-WRT
http://www.linksysbycisco.com/US/en/support/WRT150N
3.Netgear WGT624 v.4
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/WGT624.aspx
4. Paradyne ADSL router/modem (ISP's equipment)
4 laptops- 1 ps3- 1wii -1 xbox360 -1 desktop -1 AppleTv
So i think the jpg is quite clear however ill explain.
The dynex and the netgear are connected to the paradyne router/modem and the linksys has to be a wireless bridge so that i can connect the xbox360 similar to (http://www.universebot.com/2009/07/30/diy-use-a-linksys-router-as-a-xbox-360-wireless-adapter)
Things i want to accomplish:
1. have the study and the master bd laptop connected to the sdynex.
2. have the appletv connected to the dynex.
3. have the linksys connected as a bridge of the dynex so that i can connect the xbox 360 by Ethernet to the linksys.
4.have the laptop on br#3 connected to the linksys bridge wirelessly.
5. have the wii connected to the linksys bridge wirelessly.
6.have the desktop, ps3, and the laptop on room 4 connected to the netgear.
I know how to set up the electronics, i just need help with the wireless routers. I'm not sure if i need to go static vs dynamic ip, or how many routers should have DHCP enable or even NAT.
Thanks again.
Thanks,
Equipment:
1. Dynex DX-WEGRTR
Thanks again.
