Power supply compatibility
I need a new power supply because I'm putting in a new vid card, but I'm not sure about the compatibility. The motherboard I have: http://us.msi.com/index.php?func=prodmbspec&maincat_no=1&cat2_no=171&cat3_no=&prod_no=1905#menu says that it supports AXT12v power supplies. One that I'm looking at thought says its a ATX12.2v. Will they work okay together?
5 answers Last reply
More about power supply compatibility
  1. All ATX power supplies are universal make sure you get a good brand name power supply dont get some cheapo brand. Look to get a Corsair, Antec, or Silverstone
  2. I was looking at this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
    What do you think of it?
  3. I haven't seen the OCZ *stream's well reviewed. Would suggest the Corsair TX650 $70 w/ $10 MIR or Antec EA-650 $75
  4. What card are you putting in? A low power card would not require a 650W power supply, but something that eats a lot of power would.
Power Supplies Compatibility Motherboards Components Product
