Sapphire radeon hd 6870 1gb Overclocking Guide???
I have overclock my pc cpu Amd phenom ii x6 1055t at 3.6ghz(at stock fan),
Ram 4gb corsair at 836mhz(1.65v)
and now i want to overclock my Sapphire radeon hd 6870 GPU,
i have Psu cooler master 650w,
my mobo is Asus M4A78LT-M,
Now, I have overclock this 6870 at gpu clock 950,memory clock 1150 at default voltage...Is that safe?
So,what can i do for perfect performance & safe overclocking Sapphire radeon hd 6870 1gb,
thanx...
3 answers Last reply
More about sapphire radeon 6870 overclocking guide
  1. They run hot, and there's some guides out there to talk about not pushing them over 1.25 volts....
    At stock voltage, I'm pegging 95C with terrific cooling on one card. in Crossfire, they run about the same, hot as ***.
    I stopped trying to overclock it, you're not getting much more FPS out of it by pushing it.
    after overclocking at 950-1150 at stock voltage,
    max temp=79c(Weather is very hot in india)
    i check also 1hour stabilty test....every thing is fine.
    So, is that oc may help in increase fps???...
    is there any way to increase fps without change any hardware?
    OC and ???....
    OC and ???....
    Without a change in hardware, no, not significantly.
    check out the 670 FTW...I am eyeing picking up two of those in SLI to move on from my 6870 CF..
    You will need a new power supply, that coolermaster has a short life.
Graphics Cards Overclocking Sapphire HD Radeon
