Hi Guys and Gals,
I'm think that I'm having a problem with the cooler for my CPU. I'm running a Phenom II X4 965 with a CoolerMaster Hyper 212+ with a single 120mm fan on the heatsink. My case is an Antech Three Hundred Two with all optional fans installed (all fans connected to a controller). The front two fans are blowing inward, and the 2 side fans are blowing out.
I am not overclocking, running at stock 3.4 GHz with no voltage changes. When I boot, my temps sit around 32C, and when I stress test on Prime95, my temps max at 50C. I've read that the max temp you want on Prime95 when overclocking is 50C. Have I done something wrong with my setup to make the temps so high, or is this normal for a Phenom? This is the 125W TDP model.
I know that these temps aren't going to burn me out, but I thought that a cooler as awesome as this one would give me better results.
