Run a dll as an application has encouentered a problem
while starting a system a message as RUN A DLL AS AN APPLICATION HAS ENCOUNTERED A PROBLEM is appearing
1 answer Last reply
More about application encouentered problem
  1. even if the message is on startup, you should be able to get into Windows.
    Try first a system restore from
    Start>run>msconfig>launch system restore.
    Try a sfc /scannow and a chkdsk in start>run
    It's usually related to Windows rundll32 or it could be a virus.
    1. Check your Task manager procesess tab when this error happens.
    2.Look first in Start > Run>msconfig at startup and at services for weird names or rundl (with 1 L) and uncheck it.
    3.Give your PC a scan with Malwarebytes just in case.
    If not, go to right click>manage and open Event viewer.
    Look for that error, and double click it.
    Write back, with the exact App name and Mod Name.
    :hello:
DLL Windows XP
