Solved
Help Overclocking problem
I have a new PC I attempted to overclock the cpu on and after the attempted overclock the pc rebooted and won't post. I have reset the CMO's and the board won't post still. The PC powers up, but there isn't any display. My specs are in my sig.
5 answers Last reply Best Answer
More about help overclocking problem
  1. Best answer
    Pull the GPU and try to boot it.
    If it won't boot, leave it out, and pull 1 stick of ram; won't boot, try moving the ram slot to see if #1 is bad.
    I would recommend running memtest, and test all sticks of ram.
    If memtest won't boot, then your CPU might be trashed. How far did you push it?
  2. unplug / remove power electric from PSU .. find jumper CLear CMOS if you can't find remove battery mobo and wait 15minutes .... after it put it back .. what the happen
  3. I pushed it to 3.5GHz. I pulled the GPU and reseated the the RAM and now it works fine! Thanks for the help. I'm just bummed it wouldn't OC well.
    You're welcome, please select the best answer.
  5. Best answer selected by stant1rm.
CPUs Overclocking
