Solved
What Power Phase for Overclocking?
July 17, 2012 7:52:16 PM
Hey guys Im buying a New i5-2500k and will be overclocking it to 4.5ghz. Im looking at 2 different motherboards...
ASRock Z77 Pro4 - $109.99
http://www.microcenter.com/single_product_results.phtml...
and
ASRock Z77 Extreme 4 - $134.99
So a $30 Difference. The main difference in performance is
Pro4= 4+2 Power Phase; Extreme4= 8+2 Power Phase
Is the Extreme4 worth it or no?
Best solution
a c 110 K Overclocking
July 17, 2012 8:02:08 PM
In general, it's worth it, yes. I have a board with only 4+2 myself and I wish I had gotten one with a better power design.
More phases = more stable power delivery.
a b K Overclocking
July 17, 2012 8:03:06 PM
if your dead on in overclocking to a great extent, the extra power phases will help(the extreme4 will also allot 8x/8x crossfire/sli if you ever plan to)
m
l
July 17, 2012 8:03:39 PM
Thanks, Ill go with the Extreme4 then.
m
l
July 17, 2012 8:04:00 PM
Best answer selected by Obubdeno.
m
l
