I'm puzzled. My computer refuse to turn-on the first time unless I hold the motherboard power button down for a while, and then push the motherboard power button once again.
Once it does start up, it Post normally and runs stable (prime95 1 hour / furmark 30 min). I can shutdown, turn back on with the case power button after that.
Unless I unplug the power cable. Once I unplug the power cable(actually the power supply on/off switch) then plug the cable back on, the case power button don't work. To make it start again I have to hold the motherboard power button down for a while, and then push the motherboard power button once again.
I can live with that for now, but would love to resolve this. As far as I can tell, it's about my Motherboard or Power Supply, because the problem happens even without VGA card, memory, case fans and hard drive.
I am overclocking my system at 3.8Ghz, and I messed with some voltages, and it runs stable. Can some voltage stop the system from turning on? I didn't try to reset the configuration. Anyone with a similar experience?
Power Supply Corsair 850TX
Motherboard Asus P6T
