My cart:
quantity of item 1
Rosewill FE-M020-BU Black / Blue SECC Steel MicroATX Mid Tower Computer Case
Rosewill FE-M020-BU Black / Blue SECC Steel MicroATX Mid Tower Computer Case - Retail
Item #: N82E16811147152
Return Policy: Standard Return Policy
$29.99
select item 2 quantity of item 2
Seagate Barracuda 7200.10 ST380815AS 80GB 7200 RPM SATA 3.0Gb/s 3.5
Seagate Barracuda 7200.10 ST380815AS 80GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148231
$34.99
select item 3 quantity of item 3
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s 3.5
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152102
$339.96
($84.99 each)
select item 4 quantity of item 4
MSI 785GM-E51 AM3 AMD 785G HDMI Micro ATX AMD Motherboard
MSI 785GM-E51 AM3 AMD 785G HDMI Micro ATX AMD Motherboard - Retail
Item #: N82E16813130247
Protect Your Investment (expand for options13-130-247|hide options13-130-247)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info13-130-247.0.18)
* 1 year: $9.99
* 2 year: $16.99
$79.99
select item 5 quantity of item 5
Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power Supply
Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power ... - Retail
Item #: N82E16817371034
-$20.00 Instant
$69.99
$49.99
select item 6 quantity of item 6
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK - Retail
Item #: N82E16820227346
Return Policy: Memory Standard Return Policy
-$12.00 Instant
$89.99
$77.99
select item 7 quantity of item 7
AMD Athlon II X2 240 Regor 2.8GHz Socket AM3 65W Dual-Core Processor Model ADX240OCGQBOX
AMD Athlon II X2 240 Regor 2.8GHz Socket AM3 65W Dual-Core Processor Model ADX240OCGQBOX - Retail
Item #: N82E16819103688
Return Policy: CPU Replacement Only Return Policy
$58.00
select item 8 quantity of item 8
IPCQUEEN IPC-12025 120mm Case Fan
IPCQUEEN IPC-12025 120mm Case Fan - Retail
Item #: N82E16835168006
$7.98
($3.99 each)
Subtotal: $678.89
All parts from newegg.com. Total after tax & shipping will be a tad over $700. If you must fit your budget, swap the mobo out for:
ASUS M4A78LT-M LE AM3 AMD 780L Micro ATX AMD Motherboard - Retail
DDR3 up to 1800, Express Gate, Hybrid CrossFireX
$64.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131619
The big differences betwen the ASUS & the MSI is ASUS has 2 ram slots and MSI has 4. More slots = better & cheaper upgradability. i.e. 2 2x2GB kits is cheaper than a 4x2GB kit. Also, MSI has HDMI out if that matters. (to me, yes) Both mobos have 6 SATA connectors.
Why AMD? Cuz if you go with C2D, C2Q, Pentium Dual or Celeron Dual, you're building on outdated technology that's LGA 775 & DDR2. There may be a few DDR3 boards for those cpus, but the price is over $100. AM3 is here to stay. You can upgrade the AM3 cpu to anything.
Optical drives aren't necessary. Download embedded & write it to USB on another pc, and boot it up on the assembled server. You need to set up boot order in bios.
http://sourceforge.net/projects/freenas/files/
http://homeserver.wikidot.com/live-usb
