Tom's Hardware > Forum > Home Theatre > ReplayTV > IVS problems since WinXP SP2 upgrade
Forum Home Theatre : ReplayTV - IVS problems since WinXP SP2 upgrade
Archived from groups: alt.video.ptv.replaytv (More info?)
I've been having problems receiving movies since upgrading to Win XP
Pro SP2. I checked the Windows firewall settings and added Port 11111.
I also went into my SMC2804WBR and in the NAT area added the same
port. Any suggestions? I've included some additional info.
I tried checking my ID at http://www.lhaven.net/ivstest/
and received the following info:
Asked ReplayTV server about unit at ISN 00004-54831-60130.
Found on Replay server.
The IP for your ReplayTV is 68.98.8.xxx (changed for security)
The Port for your ReplayTV is 11111
Unable to contact ReplayTV unit.
500 Can't connect to 68.98.8.xxx:11111 (connect: Connection refused)
Check your port forwarding settings.
Per Router/AP
INTERNET
Cable/DSL: CONNECTED
WAN IP: 68.98.8.xxx
Subnet Mask: 255.255.240.0
Gateway: 68.98.0.x
Primary DNS: 68.2.16.xx
Secondary DNS: 68.2.16.xx
GATEWAY
IP Address: 192.168.2.x
Subnet Mask: 255.255.255.0
DHCP Server: Enabled
Firewall: Enabled
UPnP: Disabled
Wireless: Enabled
INFORMATION
Numbers of DHCP Clients: 4
Runtime Code Version:
1.11a (Dec 11 2003 14:58:14)
Boot Code Version: V1.3B
Hardware Version: 01
ip=192.168.2.xx1 name=Dell96N7231
ip=192.168.2.xx2 (ReplayTV)
ip=192.168.2.xx3 name=cx2337280-a
ip=192.168.2.xx4 name=MARKCHAN
Sponsored Links
Since the connection is independent of the PC SP2 shouldn't cause any
problems. I have SP2 and have had no problems with the RTVs or
DVArchive.
fake_address@hotmail.com
> Per Router/AP
> INTERNET
> WAN IP: 68.98.8.xxx
> Gateway: 68.98.0.x
> GATEWAY
> Firewall: Enabled
> UPnP: Disabled
> Wireless: Enabled
> INFORMATION
Reply to Anonymous
On Wed, 06 Oct 2004 04:21:46 -0700, Arawak <fake_address@hotmail.com>
>Pro SP2.
Which will make no difference (unless it's causing excessive network
activity, check for that), since IVS does not involve any of your
computers. Just the Replay and the router. What else did you do when
you upgraded to XP?
Why? See above. You could also try it with that computer(s) running XP
turned off.
>port.
Is that the port your Replay uses for IVS?
First, I'd check my Replay directly. I use.
http://66.76.26.153:29000/ivs-IVSGetUnitInfo
This also tests the port forwarding on your router. Replace
"66.76.26.153" with your public IP** and "29000" with the IVS port set
on your Replay. You should get a page that looks like:
<?xml version='1.0' encoding='UTF-8'?>
<UnitInfo isn="00004-54831-60130" nickname="Something" />
And identifies your Replay.
>Per Router/AP
>INTERNET
>WAN IP: 68.98.8.xxx
>Gateway: 68.98.0.x
>GATEWAY
>Firewall: Enabled
>UPnP: Disabled
>Wireless: Enabled
>INFORMATION
There would be no harm in giving the complete local IPs. Local IPs are
not accessible from the internet anyway. The "xx" is hiding whether or
not you are using a unique IP for the router. A conflict would cause
problems.
A firewall on the computer* will have no effect on IVS, which is not
going through your computer.
* - I would definately NOT trust a firewall that's part of XP. MS has
put in all the holes it wants, making that firewall close to useless.
However, it can't be the cause of your Replay problem.
** - If your router does not support "loopback" you'll need to use the
local IP of your Replay. Try both.
80 days until the winter solstice celebration
Mark Lloyd
http://notstupid.laughingsquid.com
Reply to Anonymous
I can't help with your problem but I have a question of my own
How do you determine either your Replay ISN (internet serial number)
or the ID that the video sharing web site wants?
Thanks in advance
Reply to Anonymous
On Wed, 06 Oct 2004 23:20:34 GMT, John in Detroit
Note that the firewall on the computer has nothing to do with IVS.
>Thanks in advance
It's easily findable in the "Setup" menu of the Replay. Select "System
Information" and then "Video Sharing". The number you want is in the
form "00004-xxxxx-xxxxx" on a 5xxx Replay ("00055-xxxxx-xxxxx" on a
4xxx). The port number (that you'll need forwarded to the Replay, but
don't need to give out) is listed there too.
Mark Lloyd
Reply to Anonymous
>>Thanks in advance
Thanks... It's not there, unit is a 5504 and apparently does not do that
kind of sharing... Will have to spoof the server and "update" it it seems
Or...... Does DVArchive have the ability to do that task? (checked the
faqs, no help there) if DV-Archive can do it I have a spare computer I
might be able to set up as a video server.... In fact long term plan IS
to set it up as a video server
Reply to Anonymous
On Thu, 07 Oct 2004 10:21:30 GMT, John in Detroit
>>>Thanks in advance
Right. The 55xx don't have that feature. Are you talking about using
5xxx software to get it? Then you should get the information display
too.
Also, for my 5080, I can access it this way to the the number:
Replace "66.76.26.153" with your public IP (or private IP if
necessary) and replace "29000" with the Replay's IVS port (it should
default to 29000 if you haven't changed it).
>to set it up as a video server.
DVA can be made accessible over the internet with the proper use of
port forwarding, but you may not want to do it. Accessing it from
another Replay requires DVA to use port 80, which is commonly used for
viruses, worms, and other nasty stuff. It's also blocked by many ISPs.
You could use a FTP server using the same directory DVA saves the
shows to (there's problems setting it up behind a router, but it's
doable).
79 days until the winter solstice celebration
Mark Lloyd
Reply to Anonymous
> doable).
Sounds like a possibility then... Long term, this is the plan... Set up
a LINUX box with decent protection and perhaps some heavy duty
passwording and use it to download a replay TV unit and make it
accessible to the net (in precisely the manner you site FTP)
I have the linux machine now and am working on getting things to work on
it, the going is slow though as... Well, I'm kind of new to the linux
field.. I"ve played in a few client accounts (all mine) over the years
but never done any "root" stuff before
Reply to Anonymous
- 0 +
John in Detroit <Blanked@sbcglobal.net> wrote in
news:2Lm9d.15003$Qv5.3217@newssvr33.news.prodigy.com:
>> for viruses, worms, and other nasty stuff. It's also blocked by many
>> ISPs. You could use a FTP server using the same directory DVA saves
>> the shows to (there's problems setting it up behind a router, but
>> it's doable).
> up a LINUX box with decent protection and perhaps some heavy duty
> on it, the going is slow though as... Well, I'm kind of new to the
> linux field.. I"ve played in a few client accounts (all mine) over the
> years but never done any "root" stuff before
You can easily run DVA on your home network over port 80 and it will
happily talk to your RTV (even with XP SP2). Then on your
router/firewall define the public port as something different, say
55002 and forward it to your DVA box on port TCP 80.
Note there is no security doing this, but then anyone using DVA on
another computer can interact with your private DVA.
I do this from work and occasionally send a show (copy/move) to work to
watch during breaks.
Reply to Steph
There are 1023 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
