Hi.
After a remarkable variety of hardware failures which I (and three different PC repair shops) have failed to trace to any clear source, I want to replace my Asus PN32E SLI + motherboard. I believe that it is responsible for the random disappearance and reappearance of one or more of my three hard drives and the gradual decline in function of my two DVDRW drives (as well as random freezing errors with messages relating to the motherboard's NVidia driver).
Could you please advise me on a better motherboard which will still have the right slots for all my hardware?
My specs are as follows:
Processor (CPU)
Intel® Core™2 Duo E6850 (2 X 3.00GHz) 1333MHz FSB/4MB L2 Cache
Motherboard
ASUS® P5N32-E SLI+: Quad-core CPU Ready, NVIDIA® Dual X16 SLI
Memory (RAM)
8GB CORSAIR DDR2 667MHz (4x2GB)
Graphics Card
768MB GEFORCE 8800GTX PCI Express + DVI + TV-OUT
Memory - 1st Hard Disk
150GB WD Raptor® SATA 16MB CACHE (10000rpm)
2nd Hard Disk
500GB SERIAL ATA II HARD DRIVE WITH 16MB CACHE (7200rpm)
3rd Hard Disk
I forget its specs, but it's also SATA, and the problems started before I installed it, so I guess it's not relevant except insofar as I need three SATA connections.
1st DVD/BLU-RAY Drive
20x Dual Layer LightScribe DVD Writer ±R/±RW/RAM
2nd DVD/BLU-RAY Drive
Power Supply & Case Cooling
600W Quiet Quad Rail PSU + 120mm Case Fan
Processor Cooling
ASUS SILENT KNIGHT II PURE COPPER ULTRA COOLER
Sound Card
Sound Blaster® Audigy® SE with 7.1 Surround Sound
Network Facilities
ONBOARD 10/100/1000 GIGABIT LAN PORT
USB Options
6 x USB 2.0 PORTS (4 REAR + 2 FRONT)
Firewire & Video Editing
2 x IEEE 1394a FIREWIRE PORTS (1 onboard, 1 at back panel)
Operating System
64 Bit Windows 7 Ultimate
Sorry if any of this information is insufficient or redundant - I am a hardware newbie. Please let me know if you know of a better motherboard which will accommodate all of the above hardware (it's primarily a gaming PC). Or, indeed, if you know of a different cause for the problem I've described.
Thanks a lot!
Processor (CPU)
Motherboard
Memory (RAM)
Graphics Card
2nd Hard Disk
3rd Hard Disk
Processor Cooling
Sound Card
Network Facilities
USB Options
Operating System
Thanks a lot!
