Then you need to start saving for a new computer! spending money on that one is like flushing it down the toilet. This is the cheapest card that would provide some gaming and it is way overpriced http://www.newegg.com/Product/Product.aspx?Item=N82E16814102814. You would need more Ram as well. At the end of the day you should be looking at a new computer instead of trying to upgrade that one. Here is a good start http://www.tomshardware.com/forum/269162-31-recommended-builds-usage
agp cards tend to be very expensive nowadays for the performance they offer... Get the cheapest one you can find if you really need one.
like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814161152
HIS Radeon 9250 128MB 64-bit DDR AGP 4X/8X $32.99
IMHO it would be better to build completely new computer...
how about going 4 aq new mother board with good inbuilt graphics card ?i update as well get a graphics card in it ?IS it better option ?is there any mother board which has inbuilt graphics?
