Power design
does anyone know how a power design efects a motherboard or have any links that explains it??
like the difference between 8, 12 and 16 power block things.
2 answers Last reply
More about power design
  1. The more power phases you have, generally speaking the more stable your overclock will be.
  2. hhhmmm cause im looking at the rampage 3 extreme and the p6x58D
    the R3E has an 8+3+3+3 power design and the p6x58D has a 16+2
    looks like the p6 would get a higher stable clock but... the r3e has dual 8 pin power plugs
    how would that effect anything??
    the p6 is a hundred dollars cheaper now i dont know if its because its 4 way instead of 3 way or what.
Motherboards Power
