Solved
Loud CPU Fan Noise, HELP!!
Hello all,
Today I put together my first PC/HTPC and everything went great except for ONE thing. The CPU fan is ridiculously LOUD. From the very beginning this thing has been very noisy regardless of CPU load. Is this normal for my CPU fan (see below)?
I also uploaded a video to youtube: http://www.youtube.com/watch?v=e3Tt4SSAMBg
This noise is really unbearable. Is there anything I'm doing wrong? What can I fix this?
Thanks in advance,
Arman
Case: Cooler Master Gladiator 600
PSU: CORSAIR CMPSU-400CX 400W
Motherboard: Asus M4A785TD
CPU: AMD Athlon II X4 620
CPU Fan: XIGMATEK nepartak - s983 92mm HYPRO bearing
RAM: 4GB (2x2GB) G.SKILL Ripjaws Series DDR3 1333 (PC3 10666)
HDD: Seagate Barracuda 7200.12 1TB
Optical: LG CH08LS10 Blu-ray Combo
OS: Windows 7 64bit
1 answer Last reply Best Answer
More about loud noise help
  1. Best answer
    Make sure you hooked up the cpu fan to CPU FAN connector on the mobo, go to bios, enable cool & quiet, and lower the cpu fan speed, save & exit. The fan speed may be represented by a % rather than RPM.
New Build CPUs Systems
