New Giga i5 machine wont boot - power cycles
Last response: in Systems
Do you have a power supply to swap and test? I have seen a similar issue and it just turned out to be that not all the power cables to the mobo/gpu were seated correctly, so that's one thing to check real quick.
Thanks - reading stickies now (first time on this forum)
Tried with PSU and CPU only connected and same behaviour.
A short or faulty PSU seem most likely.
I'll have to try and source another PSU
I tried another PSU - no change.
Tried taking MB out of case - no change.
The only change is if I connect the ATX cable the LEDs and power stay on for longer - maybe one second, instead of going off almost instantly.
Any more ideas out there?
Ask the community
