S sabired12 Distinguished Dec 16, 2011 1 0 18,510 Dec 16, 2011 #1 Hello, My flash drive is showing raw file how can solve it please?
jsmakkar Distinguished Sep 1, 2011 1,172 0 19,460 Dec 16, 2011 #2 Back up Data, if you have any. If you want to recover any data that you can't access, use free version of Recuva http://www.piriform.com/recuva Use this tool to Format your Flash Drive http://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html Upvote 0 Downvote
G Guest Guest Oct 9, 2012 #3 Usually RAW flash drive cannot be repaired since RAW means not explored or used while you have used your flash drive for quite a long time and even have photos or files stored on the flash drive. You need to recover files from flash drive for free at first if your files are important. If your files are not vitial, you may try the following directly 1, use Windows disk management to format the flash drive directly 2, if not, try format tool like http://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html Users reported that the HP usb disk format does not work on SanDisk. Upvote 0 Downvote
