Hello!
I have a problem with my gpu fan making a rattling noise in certain games. I Thought i solved the problem by using a program which sets the fan speed manually, but the problem persists. When im playing a game in full screen i can hear that the fan wont properly work. The idle fan speed is at 25% and i set it manually to 35%, then when im starting a game the fan speed decreses to 25% again. But when i play in window mode it seems like the fan speed stays at 35%, so it works to play games in window mode and this rattling sound does not appear, but i can`t play games in full screen mode.
I can also note that a while ago i played a game and the gpu started to make a really high noise, so i shut down the computer and opened the case and i noticed that a plastic part was hanging from the gpu, like the plastic from the logo on the card, i clipped off the plastic part that was hanging, thus removing the sound, but after that everytime i play a game in full screen this rattling sound appears and i notice that the fan speed won`t move from idle mode.
Could a bit of plastic from the logo destroy the graphic card?
Thanks for your help.
