okay so basicly i have no choice but to get an after market cooler as my CPU gets hot on stock speed/cooler :S
i'd be playing crysis 2 / bf3 and my CPU not OC'd goes in the high 70s - 80/81s so it is pretty bad, here are some picture of the inside my case (i redid the cable management after taking those pics)
http://i48.tinypic.com/wjckn4.jpg
http://i45.tinypic.com/10gzi4g.jpg
http://i50.tinypic.com/wikdx3.jpg
i was gonna go for the hyper 212 but i'm afraid it is not going to fit at all with the space i have available (GPU placement to the south and transistor to the north of the CPU) so i would like to know what would be a good heatsink that is rather small that would allow me to OC my 2500k to around 4GHz while keeping decent temperatures. thanks for the help
specs are:
i5-2500k CPU
BIOSTAR TZ77XE3 mobo : http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138355
EVGA GeForce GTX 570 Fermi http://ncix.com/products/?sku=57361
8GB Mushkin Enhanced Silverline Stiletto 8GB 2X4GB @ 1333MHz
Crucial M4 128 GB SSD
NZXT Hale 82 650W ATX PSU http://ncix.com/products/?sku=65503&vpn=HALE82%2D650%2DM&manufacture=NZXT
my case : http://www.ncix.com/products/?sku=57910&vpn=Z9%20Plus&manufacture=ZALMAN%20TECH&promoid=1114
to tell you how bad my stock cooler is, im playing WOW on ultra settings and my CPU reaches max temperature of 71 degree Celcius :S i did a prime95 run and after about 30-60 secs it reached 100 degree Celcius, turned prime95 off immediatly :/
someone from this website suggested http://www.amazon.com/Scythe-Samurai-SCSMZ-2100-Profile-Cooler/dp/B007R7PPJK?tag=vglnk-c1001-20 but seeing as i live in canada, amazon.com can't ship to my adress and theres none on amazon.ca
specs are:
i5-2500k CPU
