Okay, here's the deal. I have a GA-MA770T-UD3P mobo, and as far as I can tell, only the cpu header provides control via EasyTune6. I think you may be able to do voltage but not PWM to control fans put into the system headers via speedfan i(f google is correct, haven't tried yet). Either way I'd prefer to have the case fans speed decided by cpu temp, so I don't have to constantly fiddle with speedfan/controller knobs.
Anyways, my question is this. Would I be able to get the desired result using the rosewill pwm splitter followed by two 3 pin splitters to power my 4 case fans and hs fan according to cpu temp. The splitters in question:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812119248
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189063
Thanks in advance!
Thanks in advance!
