Hi, I am planning on putting together my water loop with in the next week or two. I have a question on how I should configure the loop. I plan on running one 240mm rad and one 120mm rad along with my cpu block and gtx680 block.
My question is:
Should I go
RES->240RAD->120RAD->CPU->GPU->and back to the RES
-or-
RES->240RAD->CPU->120RAD->GPU->and back to the RES
What do you think will be better for temps?
Will there be a noticeable gain in CPU temp running one RAD after the other? Or is it worth it to cool the water down after the CPU for the GPU?
Thanks for your time!
My question is:
Should I go
-or-
