hi there ,
im having some problems related to my sound card , i would really appriciate if any 1 can help me.
i searched thru the net but i havent got any answer .
i have an abit aw9d-max motherboard , it comes with an abit-max audio card which is basicly
realtek hd aduio chip , that is connected thru a special built in slot .
and i use logitech 5.1 speakers .
the audio card is connected via optic cable to a creative decoder , which is basicly like a home theater reciver but for pc speakers .
so ever since i switched from winxp to win7 , while i watch movies , every now and then
the sound just goes quite for a second , and i see in the decoder that instead of dolby digital sound
its trying to output a stereo sound .
if i connect the speakers directly to the pc , not using the decoder , then instead of this second of quite , i get a "hiss" sound coming out of the speakers .
i usually watch mkv files , but it also happens via mpg files or avi .
and the problem happens even more frequently if im donwloading ..
thanks very much for your help ...
full pc spec is :
2gb ddr2 800mhz memory dual channel (1gb x 2)
2.14ghz duo2 800fsb
geforce 8800 gts
full pc spec is :
2.14ghz duo2 800fsb
geforce 8800 gts
