I plan on building a new PC when the GTX660 comes out and have a question about the mobo and the ram speed.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643 "Mobo"
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476 "Ram"
The mobo has ram speeds of 2133*(OC)/ which I have never went beyond the stock speeds before. Can the mobo over clock the ram to the right voltage or would I have to doit by going into the Bios and changing the voltage?
Also what would be the pros and cons of doing this OC?
