Need guide to overclocking
July 27, 2012 8:29:25 AM
Hello,
my processor intel dual core e2200 @2.2 Ghz is bottlenecking my gpu zotac geforce gts 450 and i cant play games ac2,ac revelations, arkham city fluently. please help me because i cannot upgrade my cpu. i have overclocked it to 2.6 but i dont know the correct values for memory and voltage.i need maximum performance from my cpu. the system specs are :
gigabyte g41tm combo
strontium ddr3 2Gb
1360x768 display
windows 7 32 bit
max cpu multiplier is x11
More about : guide overclocking
a b à CPUs
a b K Overclocking
July 27, 2012 11:59:10 AM
Try this..
Credit to xanxaz @ http://www.tomshardware.com/forum/266962-29-need-overcl...
you FSB is at 200 in bios... try 333... without voltage increase, if not stable up the voltage 0,2 V in bios. dont go past 1.45V in any case. your CPU should hit 3.33Ghz.
m
l
July 27, 2012 4:11:03 PM
thanx i will reply after trying
m
l
a b à CPUs
a b K Overclocking
July 27, 2012 4:11:23 PM
Good luck!
m
l
July 27, 2012 4:33:33 PM
its not working . my multiplier is x11 so it was showing 3.6 i made it x10 to get 3.3 but system was not starting i tried increasing voltage by o.2 everytime until 1.418V but still no results. Is there anything to do with dram timing or cpu termination voltage or dram frequency. they were set to auto. please help
m
l
July 27, 2012 7:12:14 PM
Hey i made it to 3.0 Ghz but dont know if its stable. cpu idle temperature is 45 earlier it was 39. can i get more from my system or is it enough to play nfs the run,arkham city . please help
m
l
a b à CPUs
a b K Overclocking
July 27, 2012 7:20:00 PM
U should run Prime95 to see if its stable and if u can cool it.
m
l
July 28, 2012 4:54:25 AM
i ran prime95 but it first it was giving fatal error in core 0 that rounding was 0.5 expected less than 0.4 .Then i incresed cpu voltage to 1.425 and ram voltage to 1.6.now idle cpu temperature is 44 , prime 95 did one successful blend test but i stopped it on test 2 because cpu temperature reached 75 what should i do
m
l
