Hi all,
I just finished building my new pc.
Silverstone TJ-07
I7- 3770K
Asus Maximus V Formula
VGA MSI GeForce GTX670 2GB PM2D2GD5/OC
CoolerMaster 1000W PSU Silent Pro M2
The watercooling:
1 x XSPC Rasa Black CPU Waterblock
1 x XSPC RX240 Radiator with 2 fans
1 x XSPC RX480 Radiator with 4 fans
1 x XSPC X20 750 Pump & Reservoir combo
I did a quick OC to 4.2 ghz 1.3v and i started prime95 to do a quick test, but temps went true the roof.
They were around 90 degrees, so i stopped the test.
I used the same cooling before for a I7 2600k / MSIP67-GD65 at 4.7 ghz and temps were fine.
What can it be??
I used Artic silver 5 and i applied a rice/BB
The room temp is around 32 degrees
Silverstone TJ-07
I7- 3770K
The watercooling:
What can it be??
