4+4 or 20+4 or both to power CPU??
Related ressources:
- ForumDo I NEED to connect both the 20 pin AND 4 pin power to my mobo?
- ForumHow do I rig power supply to handle both 24-pin and 20 pin motherboard
- ForumGo for a AMD Phenom x 4 965 BE or AMD A10 5800K, both with a 6670 GPU?
- ForumCan I plug a 20+4 pin power connector into a 24 pin motherboard header
- ForumDo I have to plug in both of the 4 pin connectors to CPU
- ForumM55SLI-S 4 ---Question about Power Connector 24 pins & 20 pins
- ForumCan pentium 4 3. 20 play the latest games.
- Forumwill Swiftech H 20 -220 cool both CPU & NB?
- ForumMotherboard has BOTH 20 AND 24 pin sockets?
- ForumDoes asrock z77 pro3 motherboard require both 24 pin connector and 4 pin connect
- ForumSandy Bridge i5-2500k with 4 -pin CPU Power Connector
- ForumComputer won't power on -- problem with 4 pin connector? CPU ?
- ForumMobo recognizes both sticks, but neither BIOS nor W7 64-bit allow 4 GB?
- Forum20 4 pin power supply 24 pin motherboard
- ForumPCI Express 2.0 x16: (2x8) or (x16, x8, x 4 )... What's the difference?
- ForumNew Z77 board, MSI Mpower or Asrock Extreme4?
- ForumDual CPU Motherboards
- ForumPower Supply Problem - Kills everything or just the mobo?
- ForumFaulty motherboard/CPU cause damage to other parts?
- Forum[Solved] Can anyone recommend a good mobo for my X6 1090T CPU
- More resources
Read discussions in other Motherboards categories
If I can chose which one is best?
