GTX 670 Water Block
aquacomputers make some good designs for componits, i do not own one or know how well thay work, but i think that most are the same in performance, the rest is size and looks. i like copper blocks so i would buy this one if i had a 670.
Overclocking Expert
Quote:
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GeForce GTX 670 with 2048 MB RAM according to reference design.
You'll also want to ensure you're getting a reference 670 to install this on...or at least ensure you know the block that you do choose is compatible with the card you purchase.
Hey thanks for your input, I'm not very clear upon what it means to have a reference 670. I was planning on purchasing this card, do you think I will be able to mount the block to it? And if not what exactly should I be looking for when purchasing the card?
that is not a reference card and i could not find a full cover block for it, you might look at uni blocks and stick on ram heat sinks it works rather well for most cards.
http://www.frozencpu.com/products/5297/ex-blc-329/Dange...
http://www.frozencpu.com/products/9654/ex-blc-641/Enzot...
http://www.frozencpu.com/products/10224/ex-blc-711/Kool...
http://www.frozencpu.com/products/14170/ex-blc-965/Swif...
http://www.frozencpu.com/products/3885/vid-54/Swiftech_...
http://www.frozencpu.com/products/5557/vid-86/Swiftech_...
if that is somthing that you are willing to do, i have done this before and i know i will have to again one day.
Ok thank you, I will probably do something along this route.
Ask the community
