So I just completed my new build (htpc) and everything seems to be working great. I am running a AMD Athlon II X4 620 Propus 2.6GHz processor and am getting high temps when encoding video at load. The CPU gets as high as 70C with cores getting around 55. I was thinking about upgrading the stock cpu fan but am unsure at what size is required keeping in mind that its in an htpc case. Thanks to all.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811204037&cm_re=nmedia-_-11-204-037-_-Product
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103706
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128398&Tpk=790gx
