Help deciding on a case?
So, I've been looking at cases, and I've narrowed down my choices, however I was wondering if any of you guys could offer insight or comments? or maybe even suggestions? I need the best airflow possible, as I live in a tropical country, and when it's summer here, it goes around 30-40C.
So yeah, the 3 are:
Antec Twelve Hundred - http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043&cm_re=antec_1200-_-11-129-043-_-Product
Cooler Master HAF 932 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
XCLIO Windtunnel Black Advanced - http://www.newegg.com/Product/Product.aspx?Item=N82E16811103019&cm_re=xclio-_-11-103-019-_-Product
Thanks! :D
3 answers Last reply
More about help deciding case
  1. I have the HAF 932 and I am very pleased with it. It has been cool and quiet. Setup was easy and there is a lot of room inside. I can't provide a comparison against the other two as I've never used them but I would definately buy another HAF 932.
  2. I have a friend that had the Antec P183, then moved to an Antec 1200 and will never need or get another case.
    It has 6 fans and each of them has a controller. At the lowest settings, they are very quiet and has enough air flow to keep every component cool.
    I can't comment on the other cases, but I am going to get the Antec 1200 case as well.
    It all comes down to your personal looks and price you can afford.
  3. I wrestled w/ the same decision and went with the 1200. It has pluses and minuses as compared to the HAF 932 but the biggest advantage to my mind is it fits a CP-850 PSU.
    Antec 1200 w/ CP-850 = $244
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.345233
    HAF932 / Corsaur HX850 = $350
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
    Both PSU's get a 10 "Performance" Rating from jonnyguru.com but the CP-850 also makes silentpcrview.com's Editor's Choice List, a testament to it's quietness.
    http://www.silentpcreview.com/Recommended_PSUs
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=142
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=153
    If not building right away, you may want to wait for the DF-85 part of Antec's new Dark Fleet Series....shown at CES in January, rumor has it hitting shelves this month. Thermaltake and Coolermaster also had new things to show at CES.
    http://www.futurelooks.com/ces-2010-antec-unveils-the-lanboy-air-and-the-most-important-product-of-ces/
Power Supplies Cooler Master Cases Antec Components Product
