APPROXIMATE PURCHASE DATE: within 2 weeks BUDGET RANGE: AU$1100 (US$988)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: encoding, watching HD movies, CAD(only light), surfing the net,
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: mainly been using http://www.staticice.com.au/ COUNTRY OF ORIGIN: Australia
PARTS PREFERENCES: No preference
OVERCLOCKING: No SLI OR CROSSFIRE: No(as long as my GPU supports dual monitor)
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: 1. Just making sure the grahpics card has dual monitor HDMI support
2. Wondering whether the 700W PSU is overkill (as I'm not using SLI/Crossfire)
3. This build is focused on encoding, so parts will have to match that.
4. This is a future build, so it will need to last.
Parts:
CPU - Intel i7 920 - AU$336 (US$300) - Already Bought(on it's way)
GPU - http://cgi.ebay.com.au/Gainward-ATI-Radeon-HD4850-PCI-VGA_W0QQitemZ200422372789QQcmdZViewItemQQptZAU_Components?hash=item2eaa1ab5b5 - Gainward ATI Radeon HD4850 PCI VGA (this needs dual HDMI monitor support)
Mobo - http://www.theofficeshop.com.au/store.php?specs=23834&shopref=2 - ASRock X58 Extreme - AU$215.06 (US$193)
PSU - http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=140&bid=2&sid=50865 - Thermaltake Litepower 700W PSU - AU$90 (US$80.82)
RAM - http://www.itsdirect.com.au/com_products.php?view=detail&category_id=35&Product_ID=6845&sub_category=114&keywords=G_Skill_6GB__3_x_2048mb__DDR3_1333__PC10600____F3_10666CL7T_6GBPK__RAM_Module_Kit__Suits_Core_i7_ - G.Skill 6GB (3 x 2048mb) DDR3 1333 (PC10600) 7-7-7-18-2n 1.5v - AU$184.80 (US$165.95)
HDD - http://cgi.ebay.com.au/500Gb-SATA-2-Seagate-ST3500830AS-Barracuda-7200-10_W0QQitemZ400095197762QQcmdZViewItemQQptZAU_Components?hash=item5d27883a42 - 500Gb SATA-2 Seagate ST3500830AS Barracuda 7200.10 - AU$65 (US$58.35) - will be getting a good quality one later
Case - http://www.instantpcshop.com.au/pcshop/446/index.php?productID=4944 - Antec Nine Hundred Two 902 - AU$165 (US$148)
This comes to a total of: AU$1055 (US$946) minus the gpu, close enough to my budget
I hope I'm not missing anything, this is my first build. I'm open to advice.
Thankyou in advance
Parts:
Thankyou in advance
