Need help getting a GPU for my system!
Hi,
I was wondering if Nvidia GTX 295 series, will fit in my system without any problems.
Because I'm concerning that my PSU wont have enough power to support it.
Any suggestion will be helpful.
PS: please send me the website page for shopping and information.
26 answers Last reply
More about need system
  1. Okay, before i suggesting, please list the rest of your system... :)
  2. im using onbaord GPU right nowso here is my system:-
    Win XP 46-bit SP2,
    AMD Phenom X4 9950 Black Edition,
    8GB OCZ Dual-Channel DDR2 @ 402MHz (5-5-5-15),
    Mobo - Gigabyte GA-MA790GP-DS4H,
    1TB Samsung,
    Tochiba CD/DVDW and
    PSU 850W (but i donno wat make it is).
  3. you can run it great
    min - 650w
    great - 800 and +
  4. Should be no problems, although powersupplies are very much like paint: Some are whitewash, others fine high gloss-Have a look at the rating label and tell us what its says on the +12v line or lines, just to be sure its not whitewash;)
    As for shopping, where are you?
    As for the card, it's expensive and can be hard to find, perhaps something a little less expensive and power hungry might be a better choice? To that end, what is your monitor/s resolution/s?
  5. HD5870 is a better buy. Not quite as powerful although its close but it's also cheaper, DX11, single GPU(no scaling issues) and uses much, much less power.
  6. ^Oh dear.
  7. Quote:
    I live in UK and this is all I have found, i add some others jsut in case:-
    +12 V: 37 A
    +5 V: 53 A
    +3.3 V: 35 A
    -5 V: 0.8A
    -12 V: 1.0 A
    +5 V/SB: 2.0 A
    About that i would prefer GTX 295 because I want to use it atleast minimum 5 years and more. untill there are high recommended games that cant handle it in the future.
  8. Quote:
    You can run it like butter and cream AND DONT LISTEN TO THE GUY THAT SUGGEST HD 5870. GTX 295 has better performence and its cooler and nvidia has far better quality.
    true, I had XFX ATI hd 4870 x2, it was broken and i send it to RMA and they got me a new 1 and it was still faulty and i have been waiting for 2 months and more for it untill i got bored waiting. so i ask them for my money back.
  9. Please recheck the rating label: 37A on the 12v output sems very low, you may have miread it, although, given the high +3.3v and +5v outputs it looks like it is a less expensive unit, based on an old design.
    If you have not misread it (and it is easily done) that PSU should not be used for a GTX295, it does not have enough output on the +12v line for such a card.
    For a replacement PSU look for: Antec, OCZ, Corsair and Seasonic as top notch, with Thermaltake and Coolermaster as cheaper, not quite so good suppliers.
    A few places to begin your hunt: Dabs, Novatech, CCL, Ebuyer, Scan, Pixmania, Microdirect and Overclockers.
    So what do I need to know which 1 is the right PSU to buy, because the PSU might be low, but i read it right. its stats like that.
  11. I'm thinking if this 1 is right for my system included the GPU (GTX 295) that im going to add.
    http://www.ebuyer.com/product/135197/show_product_video/playvid#
  12. Something like this is a better choice, lower Wattage but much higher quality. And it's modular, so no messy cables.
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-031-OC&groupid=701&catid=123&subcat=1098
    This is not the only one out there, I'm just giving you an example of what to look for, a quality unit with the right outputs and connectors (OCZ website shows it as having 2X 25A +12v outputs, plenty for the GTX295).
    But GTX 295 required minimum 650W and its state on the guide book, how will 600 support it then??? just curiose.
    Maybe you should take that as a reason to avoid dual GPU cards instead. Just sayin...
  15. The 650W requirement is not the main issue, it is the +12v output that is importaint, as long as a powersupply can match, or exceeed that requirement, and has the correct connectors, you'll be fine.
    If you want more peace of mind, go for something larger, but quality and +12v amperage is more importaint than wattage.
    Again, just as an example:
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-032-OC&groupid=701&catid=123&subcat=1098
  16. Yes, it's the +12v rail that matters a lot moreso than the supposed overall power. If your current unit really only has 37 amps it's quite possible that those HD4870x2s that you mentioned weren't faulty at all, they simply weren't able to run on that PSU.
    Looks like OP just got a revelation.
    thanks. I just realized it, i didnt knew that +12 v rail had to do with anything. I thought Watt was important :S
  19. Watt = (Newton * Meter) / Second
    (n*m)/s.
    Someone fell asleep when their science teacher was discussing voltage, wattage, amperage.
  20. The PSU is nice, but maybe you should get a 5870 instead?
    Why do u recommend 5870 then GTX 295??
  22. I already went over that earlier in the thread;
    "HD5870 is a better buy. Not quite as powerful although its close but it's also cheaper, DX11, single GPU(no scaling issues) and uses much, much less power."
    Overall the GTX 295 is about 10-15% faster but the HD5870 is better in almost every way otherwise. I didn't even mention eyefinity which is pretty cool if you are interested in it;
    http://www.youtube.com/watch?v=5UeHJEeuLc8
    I never recommended the GTX 295.
  24. @ Sabot00: Watts also= W=VxI (Watts=VoltsxAmps), your equation is for mechanical Wattage, not electrical;) , there is a difference.
    As for the card, I would have suggested the HD5870, but if the OP wants a GTX295, and has made his (or her) view clear.
  25. The 295 uses 194 watts ...for comparison purposes.....
    http://www.tomshardware.com/reviews/geforce-310-5970,2491.html
    Here's the "winners" from THG's latest (December) GFX Roundup
    Best Graphics Cards For The Money: December '09
    $50 - HD 4650
    $65 - HD 4670 / 9600 GSO
    $85 - 9600 GT
    $95 - 9600 GT / HD 4830
    $110 - GTS 250 512 MB
    $120 - GTS 250 1 GB
    $155 - HD 5770 / GTX 260
    $200 - HD 4890
    $240 - 2 x GTS 250
    $310 - No winner (HD 5850 Honorable Mention)
    $330 - 2 x GTX 260 / 2 x HD 5770
    $400 - 2 x HD 4890
    $410 - No winner (HD 5870 Honorable Mention)
    $465 - No winner (GTX 295 Honorable Mention)
    $625 - No winner (HD 5970 Honorable Mention)
Nvidia GPUs Graphics
