Pentium D 920 Overclocking problem
Hi Guys, I am in safe mode right now because i have a problem , after i use clockgen overclocking i was like roaming around then suddenly when i clicked something there my screen turned blue then changed to another color after that i restarted my computer and then everything was black so i took out the SVGA connector and plug it in the Back panel connector in the motherboard and it work fine. So when i went to safe mode i tried to pull back out the SVGA connector and plug it back to the connector for the graphics card and poof it was still black .. please help me.. :( :( :( :( :( :(
2 answers Last reply
More about pentium overclocking problem
  1. try removing the jumper pins, with the power off of course
    it will look like that, colour and shape may somewhat vary
    if you cannot find it you can remove the battery for about 30 mins - 1 hr
  2. Post your specs, have you oc'd with out using clockgen? :hello:
CPUs Overclocking Safe Mode Pentium
