Alright, i found a motherboard, and just when i was about to buy my entire build, i see that the motherboard was "recertified" meaning it came with nothing and sucked ass! That pretty much ruined my day.
So, i need a motherboard that supports 2000MHZ ram. up to 8GB of it.
Unless 1600MHZ is almost as good? because i know its cheaper.
This is my first build, so im not sure if i should go with 2000MHZ or 1600MHZ ram..
Heres the motherboard that i chose before i found out its recertified.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4349464
Processor Socket: Intel
Processor Interface: Socket 775
Form Factor: ATX
Memory Type: DDR3
Number of Pins: 240-Pin
Number of Slots: 4
Maximum Memory Supported: 8GB - 64bit
That supports this processor:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3952342&CatId=2758
That will support this graphics card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125293
Thank you very much!
Form Factor: ATX
Memory Type: DDR3
Number of Slots: 4
