Will this work with x58 motherboard rampage 3
Last response: in Memory
July 29, 2010 4:14:27 AM
will that work with a x58 motherboard?
its the same as this
but it says diff Compatiblity
thanks
a b } Memory
a b V Motherboard
July 29, 2010 4:34:17 AM
Just because it's not on Asus's Qualified Vendor's List for memory doesn't mean it won't work, it should. Don't see why it wouldn't.
m
l
July 29, 2010 4:47:16 AM
but the one i want the top one says this "Compatible with Intel P55 chipset"im not sure but will that still work with a x58 chipset?
also is that the best gskill ram cards, i want 4 gb chips.thanks
m
l
a b } Memory
a b V Motherboard
July 29, 2010 4:50:16 AM
It would... that P55 but it must be a glitch/typo.
I suppose that RAM is one of the best kits available from G.Skill, but do you really need 24 GB?
m
l
July 29, 2010 4:56:56 AM
umm, i guess i need that looking towards the future with this build. so its the same the p55 as the x58 one. just making sure since it is a bit , just want to be positive. im not sure bout the speeds and all that , but is the one i want good, i think it was 7-8-7-24 while i saw another gskill ripjaw 9-9-9-24
m
l
a b } Memory
a b V Motherboard
July 29, 2010 5:16:13 AM
For a 3x4 GB kit, those timings are very good I reckon, bit on the pricey side though.
m
l
July 29, 2010 11:26:19 AM
I kind of made this topic late if anyone else can give me some input that would great I still kind of lost on this whole ram thing my main concern is if the p55 will work with the x58 if it's a typo or what not really sure bout newegg and all that thanks a million to anyone that helps out
m
l
a b } Memory
a b V Motherboard
July 29, 2010 11:38:02 AM
It's not a P55 kit, I'm pretty sure it's a typo - P55 needs dual channel, this is a triple channel.
Newegg is pretty bad with specs sometimes. With the Core i5 760 they said it was a 32nm Hyper-Threaded quad core, it was a 45nm quad core w/o HTT.
Trust me, that kit WILL work, unless it's DOA. Lol.
m
l
July 29, 2010 12:50:01 PM
Oh ok thanks buddy and do you know that if it's the best langency and all that I'm not sure thanks
m
l
July 29, 2010 2:00:14 PM
I am pretty sure any type of RAM that is DDR3 works with x58 motherboards. Some mother boards have a memory standard, like one might only accept 1600 RAM or higher, the other might accept 1333 or higher. The Rampage 3 Extreme accepts all types of DDR3 memory.
m
l
July 29, 2010 2:08:01 PM
Ya it does the lantecy all that the lower the better right
m
l
a b } Memory
a b V Motherboard
July 29, 2010 8:32:05 PM
Yes, lower the latency the better.
m
l
