Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Antec 1200 AUDIO PROBLEMS
Forum Systems : Homebuilt Antec 1200 AUDIO PROBLEMS
i have transferred my old pc parts in to mi new antec 1200 case, a ASTEROPE GL8E MOTHERBOARD, pentium 4 3.06ghz processor, 2gb ram, 200 gb hard drive. i also included a 700 watt power supply and i put in a msi gtx 275 vga. everything runs good except the two audio jacks at the top of the case. only the mic works, i cannot get any audio for the headphone port. can someone help me
Reply to jcharrison86
Did you try switching the front audio cable going to the motherboard to the other plug?
------------------------------ How to Ask for New Build Advice
Troubleshooting
Reply to MadAdmiral
i have this case. and same problem.... but they worked when i had vista installed, haven't worked since upgrading to win7
Reply to kayotic18
My antec 900's front minijacks doesnt work neither. I've tried switching between AC'97 and HD audio, doesnt work.
------------------------------ -And there was light-
Reply to boldor
If the systen uses RealTek go to Audio Manager, selelct 'Connector Settings' (the picture of a file) and unselect 'Disable front audio jack selection', i.e. there is no tick for this box.
I had the same problem on one of my new builds, and found this solution on Tom's Hardware.
Reply to stuporman
Im using an aftermarket sound card. The Asus Xonar. And i cannot find that option in the software...
Reply to boldor
There are 1914 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$600 Budget Gaming Build - Advice Appreciated
By coffeecoffee, 6 hours ago:
Alright, your on the right track. There are a few changes I would like to make if I...
Best offers
Top experts
