I was looking at using my 8800GT as a PhysX card with my GTX275. I'm using a Corsair HX620W PSU.
The PSU only has 2 PCI-E 6 pin outputs, both of which are being used by the GTX275. The 8800GT needs one when it's used for primary graphics.
Do I still need to connect the PCI-E power output to the 8800GT if I'm just using it for PhysX?
If so, is there another option besides replacing the PSU with one that has more than 2 PCI-E outputs?
I just wanted to try this out on my current build. I'm upgrading to an X58 system in the next month or so. So I could include a new PSU in that build if needed. But didn't want to if I didn't have to.
Thanks for any help/advice.
