Shall i place 1tb hard disk in place of 500 gb hard in laptop
shall i place 1 tb hard disk in place of 500 gb hard disk in laptop
5 answers Last reply
More about shall place hard disk place hard laptop
  1. Yes you can as long as the motherboard is capable of handling 1 TB drives. You can verify this in the specs. found in the manual.
  2. Sure if you have a 1 tb HDD. Otherwise you could consider a smaller SSD, if you want speed.
    Thanks for your information... But I mean to say that the Physical Size of the 1tb Hard Disk can sit into the 500 GB hard Disk Slot...
  4. If they are both the same size (2.5 inch), thickness (9.5mm or 7mm) and same connector (SATA), then yes.
    Normally yes!
    However, verify the thickness (height) and other dimensions of the 1 TB drive. You can do this by downloading and running SPECCY - http://www.piriform.com/speccy
    From this you can obtain the hard disk details and model and serial number. Then go to the manufacturer's website and read the specifications which will list the physical dimensions.
    Another way to do this is to take the disk out and take it to a computer store like MicroCenter and verify the physical dimensions. In most instances, a thicker hard disk such as the 1 TB hard disk will fit.
    When changing from a 500 GB to a 1 TB hard disk, the thermal profile will be altered. If the heat produced is equal or less than the old 500 GB then it will be ok. If not, there may be new heat related problems created in a laptop.
Hard Drives Laptops Storage
