Aloha,
I am building a system based off of two hand-me-down parts from friends. They are:
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115037&cm_re=e8400-_-19-115-037-_-Product
and GPU:
Nvidia 8600 GTS (I will upgrade this at a later date)
I also have an antec 400watt PSU, windows xp, and an antec case from 2004
here are the other components I have chose:
Motherboard:
ASUS P5E3 PRO LGA 775 Intel X48 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131600
DVD Burner:
LITE-ON 24x DVD Burner - Bulk Black SATA Model DH-24AAS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106339
Hard Drive:
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
RAM:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
i was originally looking at the "GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard" or the "ASUS P5Q SE PLUS LGA 775 Intel P45 ATX Intel Motherboard,"
but I dont know if there is any reason to buy DDR2 now instead of DDR3?
they seem to be the same price!
I plan on updating gpu and OS later. Im hoping this board/cpu will last a couple years. last system has lived quite a while.
I will also buy an aftermarket cpu cooler when i buy a new GPU.
what I'm going to be using this system for:
light gaming: cs:source, league of legends
disassembling
programming
surfing the web
watching .avi's
My questions:
1) Is all of this compatible(from checking the Asus site it says the cpu is)
2) is this a wise idea? remember, the CPU and GPU are free.
3) any other thoughts?
thank you in advance
and GPU:
Motherboard:
DVD Burner:
Hard Drive:
RAM:
disassembling
programming
surfing the web
watching .avi's
My questions:
