Hello all,
My thanks in advance to any help. It is much appreciated.
As I said in the title, I have an NZXT Source 220 case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146083
Fan Placement Options:
2 x Front (120 mm)
2 x Bottom (120 mm)
2 x Top (120mm or 140 mm)
1 x Back (120 mm)
I have settled on an ASRock Z77 Extreme4 MOBO (had a hard time deciding between that or the Gigabyte GA-Z77X-UD3H. Still time to change, I order tomorrow, so if you have hard evidence why UD3H instead inform me please!!!): http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
The case came with 1 x 120 mm fan in the back (exhaust I assume) and 1 x 140 mm fan in the top (exhaust as well?). I bought 3 CM SickleFlow 120 mm fans: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103060
I know these fans aren't top of the line, but they ended up $2.99 a pop AR so I'm happy with that.
I am not too picky on noise. I prefer the integrity of my PC over noise level.
My knowledge tells me heat rises so I was thinking two intakes in the front (bought 2 Silverstone magnetic filters) and one intake on the bottom (need to purchase another filter) with the top 140 mm and the back 120 mm as exhaust. This seems most logical to me...
but where would you suggest I put the three CMs?
2 x Front (120 mm)
2 x Bottom (120 mm)
1 x Back (120 mm)
