Core i7920 turbo boost problem?
i downloaded turbo boost meter from intel.com and it shows you if your processor is using turbo boost. Well mine is but the problem is that its always on. Like its always running at 2.8 ghz instead of the normal 2.6. i thought turbo boost was only supposed to kick in when you needed it, like playing a game or something. How do i fix this?
9 answers Last reply
More about core i7920 turbo boost problem
  1. help
  2. Try CPU-Z instead ... if it shows you running on turbo all the time, check Task Manager and see what's cranking on your CPU.
  3. cpuz says its running at 2.8ghz. i checked task manager and theres absolutely nothing running in the background. cpu usage is at 0-1%. Is there maby a setting that should or shouldnt be enabled in the bios like speedstep or something
  4. i just installed it on my computer and it says at idle it runs at 2.6 but everytime i open a program it jumps up. i have the intel i7 920 two.
  5. Do you have C-states and speedsted enabled in the BIOS?
    What processor do you have?
  6. ok you lost me. i don't know what C-states and speedset are. The only thing i changed in my BIOS was my memory so it would run at 1600. I have the intel i7 920.
  7. In your BIOS there should be a menu, either of power saving feutrues or processor features. Find it and you should see an option for Intel Speed Step enable/disable and C-States enable/disable
    Speed Step lets the CPU throttle back under light load and C-states allow it to basically take a nap
  8. oh i see thanks hey do u know how to get rid of blue screen
  9. Also it can depend on what your power properties are set to. On mine for a while cpu-z would always show mine at 21x multi no matter what it was actually at. Also the actual multi would bounce around a lot when idle. I found the solution was to (using XP) change the power properties from desktop to portable/laptop. That allowed it to have a stable 12x at idle and 21x at load and cpu-z started to finally report the correct multi.
    Here is a shot showing what it looked like with cpu-z reporting the incorrect multi.
    And here is a shot of what I changed to correct the problem.
    And same was true in W7 RC but had quite a few more options to set but I started with power saver mode and changed from there.
CPUs Core Processors Turbo Boost
