Power supply problems
I replaced a motherboard and found that the new one is 24 pin.
Would this cause my video and a few other components not to work?
Should I change the power supply to a newer one?
4 answers Last reply
More about power supply problems
  1. All will work till you are in the right mindset..
  2. Huh? Itll work fine, as long as your PSU has a 24 pin output or you have a 20 pin to 24 pin adapter itll be fine, motherboard doesnt draw much power at all
  3. Thankyou, I appreciate your reply
  4. No problem, just glad to help
Power Supplies Motherboards Components
