First Build - $1,100 CAD - Need Advice!
Last response: in Systems
Hello Community - I could really use some tips/suggestions/advice.
Looking to replace my old machine (4+ years) with my first home build. Planning on making all purchases from Newegg.ca in the next couple of days.
The most intensive use of the system will be gaming - not looking to play games at Max settings, just looking to be able to play them without FPS issues with about medium settings (have had my old machine for 4+ years, so any real improvement is a leap :)
Not looking to overclock anything - everything will be running at stock speeds.
This is what I'm thinking - please let me know what you think...
MB - ASUS SABERTOOTH 55i LGA 1156 Intel P55 ATX Intel Motherboard - $219.99
CPU - Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core - $219.99
GPU - EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 - $225.99
RAM - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) - $101.99
HDD - Western Digital Caviar Black 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal - $114.99
CASE - Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - $89.99
PSU - COOLER MASTER Silent Pro 600W ATX12V V2.380 Modular - $99.49
OPTICAL - Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA - $32.49
TOTAL - $1,104.92 (Before taxes and shipping)
This is a LITTLE bit more than I was hoping, but I'm willing to spend it if it's worth it. I know some people will suggest I switch to an ATI card, but I am kind of partial to nVidia.
Should cooling be an issue if I'm not overclocking and the case has 4 fans?
Anyone foresee compatibility issues?
Should this 600W PSU be sufficient? I've checked a few online calculators and most tell me about 500W...
Looking to place an order in the next day or 2, so any replies before then would be great :)
More about : build 100 cad advice
Mobo: Asus P7P55D-E Pro $200. It's more future proof with USB 3/SATA III ports for less.
GPU: HD 5770 $167. Cheaper, relatively same performance, cooler, quieter, more future proof and more efficient. If you're partial, you will get a worse machine than you could have.
RAM: For a few bucks more (I think it's $105), you can get CAS Latency 7 sticks which will be a lot better.
HDD: WD sucks right now. Grab a Samsung Spinpoint F3 1 TB (if you can). If you can't find one on Newegg or elsewhere, the Seagate 7200.12 is the next best thing. Both are faster, quieter, cooler and cheaper. I don't know Canadian prices, but in the US the F3 is $25 cheaper (so probably $30-40 CAN).
PSU: I'd stick to Corsair, Antec Earthwatts or OCZ. OCZ's StealthXStream 700W is super cheap right now.
My changes will probably put you under $1,000 CAN.
You're fine on cooling if you're not overclocking.
No compatibility issues.
600W is way more than you'll need, but I suggest the 700W because it's so darn cheap right now.
ZombieBob, why are you even getting a last-gen GPU? A mid-end at that. If it is GTX 275/285, then it's better. Still ATI won the GPU war. There's no reason to go nVidia right now UNLESS your games scream for it. i.e. Crysis. Or if you run Linux exclusively.
my cart:
quantity of item 1
Sony Optiarc DVD Burner with LightScribe Black SATA Model AD-7241S-0B LightScribe Support
Sony Optiarc DVD Burner with LightScribe Black SATA Model AD-7241S-0B LightScribe Support - OEM
Item #: N82E16827118032
Return Policy: Standard Return Policy
$28.49
select item 2 quantity of item 2
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply - Retail
Item #: N82E16811129024
-$50.00 Instant
$159.99
$109.99
select item 3 quantity of item 3
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136284
$114.99
select item 4 quantity of item 4
ASUS EAH5850/2DIS/1GD5 Radeon HD 5850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
ASUS EAH5850/2DIS/1GD5 Radeon HD 5850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card - Retail
Item #: N82E16814121361
Return Policy: VGA Standard Return Policy
-$10.00 Instant
$325.49
$315.49
select item 5 quantity of item 5
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK - Retail
Item #: N82E16820227346
Return Policy: Memory Standard Return Policy
$78.99
select item 6 quantity of item 6
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
Item #: N82E16813128412
$149.99
select item 7 quantity of item 7
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
Item #: N82E16819115215
Return Policy: CPU Replacement Only Return Policy
$219.99
Subtotal: $1,017.93
This will beat the crap out of your original build in terms of gaming. The mobo is a budget ATX board with USB 3 & SATA 6. You need ~$1400 CAD for a build with a better board like the ASUS, case & PSU.
The downside to p55ibexpeak's build is that the motherboard only has one PCI-E slot, so you wouldn't be able to crossfire. What I would do to retain that possibility is get one of the cheaper mobos that has two slots at x8 or above. Also change the PSU, as I have read that the Cooler Master Silent Pro line isn't very good when it is asked to support more than one video card, the OCZ StealthXStream would be the perfect choice and a lot cheaper, so bringing you back under budget and still having a very good system with upgradeability in the video card area.
Second what Silvune said. In addition, the OCZ StealthXStream 700W has a Newegg combo with the HAF 922 for $100 after rebates. Or at least they did yesterday...
EDIT: Forgot that this was a Canada thread. The combo was on the US side, and the price may be a little different.
Ask the community
