Hi guys. So I'm a newbie overclocker. Could really use some help here. Sorry if the question is stupid.
System specs:
phenom ii x4 955be deneb 3.2ghz Black edition 125W (c3 stepping)
Corsair h60 cooler
750watt corsair power supply
8gb 1333mhz sd ram (corsair)
Dual 5770 sapphire crossfire setup
Gigabyte 890gx motherboard which can supposedly handle 140W processors.
I overclocked using the multiplier alone to 3.6ghz with stock voltages(1.392vcore for my processor)
Ran prime95 for 8.5 hrs and all is well.
Temps 57 Celsius with prime95 ( if room AC is off goes up to 59/60)
Gaming temps 49 - 52 Celsius
Idle 40-42
Disabled cool n quiet, PCIe spread spectrum, and c1e in bios.
Changed voltages from auto to manual.
All seemed well..
Then I entered my overclocking values into the online extreme Power supply calculator And it showed that my CPU wattage for the overclock is 149W
My board was designed for 140W
Am I killing my motherboard?
Does the wattage matter?
Again I'm sorry if the question is a complete newbie question.
This is my first overclock.
Don't understand everything as yet.
Any help or advice would be greatly appreciated.
System specs:
Corsair h60 cooler
Idle 40-42
All seemed well..
