My newly built system will not turn on. There is no sign of life at all when I push the power switch on the case except a brief, millisecond-long flash of the power and HDD leds. There are no fans turning on, no lights on the mobo, nothing.
Does anybody have any suggestions? Already tried:
-Unplug and replug the PSU, double-check that the voltage was right, make sure the on/off switch on the PSU was in the "on" position
-Double-check connections from front panel to the mobo
-Double-check the 12V connection by the CPU and the bigger power connection to the right
-Check spacers to make sure the back of the mobo isn't touching the case anywhere
