Highest athlon x3 440 clock speed with stock cooling?
i have my cpu oc @ 3.6 right now and my temps never get of 50c and i was wondering whats the highest clock speed i could be able to get with stock cpu cooling (i have great case cooling)
More about : highest athlon 440 clock speed stock cooling
Related ressources
- Does unlocking the 4th core on an Athlon II X3 440 raise its TDP? - Forum
- Safe to use a Phenom II X3 720 stock cooler w/ an Athlon II X3 440 ? - Forum
- 4th core of Athlon X3 440 and Temperature - Forum
- Is Athlon II X3 440 powerful enough at stock speed ... - Forum
- Athlon ii x3 440 - Forum
You are going about this wrong. The real questions are....What is your max budget? What exactly are you trying to do? Just overclock what you have or a complete upgrade? What goals do you have for an upgrade? For instance if you want better gaming performance leaving the CPU alone and getting something better than a GTX 550 Ti would be a better path to improvement. What resolution do you play at and what are your entire system components including power supply make and model?
I'm saying your CPU will not bottleneck a card up to a GTX 560 Ti. Anything over that and a new CPU or at least an overclock of what you have would be needed. Once again resolution is important. At lower resolutions the CPU is more important and at higher resolutions the GPU becomes more important.
The GTX 550 Ti is an entry level card at best. The first thing I would do in your situation is upgrade the graphics. Unless you plan on building a completely new computer.....motherboard, CPU, RAM and GPU.
So as I asked above.......what is your budget? What are you trying to gain from any upgrade ? What is your monitor resolution?
If you want gaming performance a new PSU/GPU make much more sense than just getting a new motherboard and CPU. Hell something like an HD 7850 only needs a recommended 450w power supply.
http://www.anandtech.com/bench/Product/549?vs=541
A GTX 560 Ti needs recommended 500w power supply. If you had a good quality model I would say you would be fine but that Ibuypower Arctic model is not know to be a quality unit. The HD 7850 is just as good as the GTX560 Ti though and actually better in quit a few benchmarks and it uses much less power. I would feel safe recommending an HD 7850 with the PSU you have now.
http://www.anandtech.com/bench/Product/547?vs=549
You have seen the Tom's hierarchy chart?
http://www.tomshardware.com/reviews/gaming-graphics-car...
They recommend an upgrade be at least 3 tiers up to really notice a difference.
The GTX 560 Ti is 3 tiers up and the HD 7850 is 4 tiers up.
this is more in my price range
Why would you get a last gen card that requirs a new power supply rather than a HD 7850? The 7850 only needs a recomended 450w PSU so you would not have to upgrade. It's also a much more powerful card. Basically the newer the card the less power is required for the same or better perfomance than an older card.
Related ressources:
- ForumAmd athlon x3 440
- ForumGood CPU Cooler for an Athlon II x3 440 Overclocked & Unlocked?
- ForumBest Gaming CPU: Athlon II X3 440 or Phenom II X2 555 Black Edition
- ForumAthlon X3 440 with 4th core OCing
- ForumAthlon II x3 440 Build. Final Check.
- ForumShould I connect all my case fans to a PWM slot?
- ForumAm I damaging my motherboard with my overclock? Help?
- ForumHelp with a fan connection
- ForumHelp with first time o.c.
- Forum[Solved] Help; Basic OC Problem with fixed Parameters
- Forum[Solved] 1090T stable at 4.0ghz but core temps up to 60c!
- Forum[Solved] Stock i5 2500k temp w/ 212 evo
- ForumWater cooling in Hafx,CM Storm Troop or?
- Forum[Solved] Lego case cooling
- ForumNeed help making a fan speed controller
- More resources
Read discussions in other Overclocking categories
